It is currently Tue Jun 24, 2025 7:23 am
PostPosted: Tue Apr 11, 2006 4:58 am
I was wondering whether you folks glue the nut in place on the neck, or just have it fit snugly in the slot?
I've noticed a number of repairpersons "fixing" my guitars by adding a couple of drops...
PostPosted: Tue Apr 11, 2006 5:00 am
i put a tiny drop of white glue on the bottom, spread it around a little and set it in place, then I tighten up the strings, that provides the clamping pressure.
PostPosted: Tue Apr 11, 2006 5:01 am
I actually put a tiny dot of white glue on the side of the nut toward the
fretboard
PostPosted: Tue Apr 11, 2006 5:20 am
State: ON
Just enough glue to hold it in place. Like Lance said a drop is really all you need. That way it doesn't go anywhere but it will be easy enough to remove and replace if needed.
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Tue Apr 11, 2006 5:33 am
A little drop will do the trick.....but I guess more wouldn't hurt either
PostPosted: Tue Apr 11, 2006 6:07 am
I try and get as snug a fit as possible and then put a piece of Duck double side tape under the nut.
PostPosted: Tue Apr 11, 2006 1:24 pm
Dave, You put tape under the Nut?
PostPosted: Tue Apr 11, 2006 4:11 pm
I make as tight a fit as I can and then put in a few drops of PVA or cyano.
Oh yeah and if youre using cyano..make you wash your hands before
handling any other nuts.kiwigeo38819.0509606482
PostPosted: Tue Apr 11, 2006 6:20 pm
Snug as a bug and two small drips of white.
PostPosted: Wed Apr 12, 2006 12:35 am
Richard,
Yes. The fit of the nut is snug in the first place, and the string pressure on the double sided tape fits it even more snugly. The tape has virtually no thickness and when you want to take the nut out it releases real easy and peels of the bottom of the nut clean as a whistle. I've been doing this for over 2 years now with no problems at all.
PostPosted: Wed Apr 12, 2006 12:41 am
Last Name: Bordeaux
City: Massena
State: New York
Zip/Postal Code: 13662
I fit the nut in snug; no pressure. Then a few drops of thin CA at the fingerboard/ nut joint. Been doing it this way for 20 years. Remove with a light tap from the F.B. side.
Paul Bordeaux
http://www.bordeauxinlay.com
PostPosted: Wed Apr 12, 2006 12:50 am
I thin out some titebond a little and apply a couple small drops.
PostPosted: Wed Apr 12, 2006 1:16 am
[QUOTE=kiwigeo] I make as tight a fit as I can and then put in a few drops of PVA or cyano.
handling any other nuts.[/QUOTE]
Yes, yesterday I forgot to do this and am now typing with my nose!
PostPosted: Wed Apr 12, 2006 3:57 am
Dave I would wonder if that might have some affect on sound although I imagine it would be very marginal. I've used white glue and CA but have stuck to white glue. Tight fitting nut and then a little glue holds it great yet comes out real easy. Orriginally I didn't use any glue but customers didn't like this.
PostPosted: Wed Apr 12, 2006 4:16 am
Richard,
I don't think the sound is impacted one iota. I play the guitars a lot to make sure everything is fine before I finally put the tape on and then play them afterwards.
That Duck stuff can be pretty tenacious. Once in a small travel guitar I made the mistake of putting some on the bridgeplate caul while the bridge was clamped on. It took me 3 days of painful contorted wriggling to break the glue bond and get the caul off Dave White38819.5538425926
PostPosted: Wed Apr 12, 2006 4:38 am
Snug fit, no glue. If it can come out with no strings on, without some persuassion, then it's not snug enough. We don't glue in the saddle do we?
PostPosted: Wed Apr 12, 2006 5:03 pm
[QUOTE=Dave White] Richard,
painful contorted wriggling to break the glue bond and get the caul off [:
s][/QUOTE]
Reminds of a guy I know who spent 12 months chasing a buzz on his
classical and then discovered the bridge caul still sitting under the top....
PostPosted: Wed Apr 12, 2006 10:06 pm
[QUOTE=L. Presnall] Oh yeah and if youre using cyano..make you wash your hands before
Yes, yesterday I forgot to do this and am now typing with my nose! [/QUOTE]
rolling on the floor
PostPosted: Thu Apr 13, 2006 10:51 am
[QUOTE=kiwigeo] Reminds of a guy I know who spent 12 months chasing a buzz on his
classical and then discovered the bridge caul still sitting under the top....[/QUOTE]
Now THAT'S entertainment!!!
PostPosted: Fri Apr 14, 2006 4:50 pm
ColinS,
I don't, snug fit, no glue
PostPosted: Mon Apr 17, 2006 10:23 pm
Snug (tight) fit, drop of white or yellow PVA.
